Create an obstacle that cannot be stepped in
Hi there. I want to build a cuboid obstacle in front of a humanoid robot model in Gazebo. But when the robot steps on the obstacle, its feet are in the cuboid obstacle. How can I change the parameters so that the feet of the robot won't intersect the obstacle? Thanks in advance. image description
<?xml version='1.0'?>
<sdf version='1.6'>
  <model name='unit_box_0_1'>
    <link name='link'>
        <mass>1</mass>
          <ixx>0.166667</ixx>
          <iyy>0.166667</iyy>
          <izz>0.166667</izz>
      <kinematic>0</kinematic>
      <gravity>1</gravity>
      <visual name='visual'>
            <size>0.15 1 0.1</size>
          <script>
            <name>Gazebo/Grey</name>
          </script>
          <ambient>0.3 0.3 0.3 1</ambient>
          <diffuse>0.7 0.7 0.7 1</diffuse>
          <specular>0.01 0.01 0.01 1</specular>
          <emissive>0 0 0 1</emissive>
          <shader type='vertex'>
            <normal_map>__default__</normal_map>
          </shader>
      <collision name='collision'>
        <laser_retro>0</laser_retro>
        <surface>
          <friction>
            <ode>
              <mu>1</mu>
              <mu2>1</mu2>
              <fdir1>0 0 0</fdir1>
              <slip1>0</slip1>
              <slip2>0</slip2>
            </ode>
            <torsional>
              <coefficient>1</coefficient>
              <patch_radius>0</patch_radius>
              <surface_radius>0</surface_radius>
              <use_patch_radius>1</use_patch_radius>
              <ode>
                <slip>0</slip>
              </ode>
            </torsional>
          </friction>
          <bounce>
            <threshold>1e+06</threshold>
          </bounce>
          <contact>
            <collide_without_contact>0</collide_without_contact>
            <collide_without_contact_bitmask>1</collide_without_contact_bitmask>
            <collide_bitmask>1</collide_bitmask>
            <ode>
              <soft_cfm>0</soft_cfm>
              <soft_erp>0.2</soft_erp>
              <kp>1e+13</kp>
              <kd>1</kd>
              <max_vel>0.01</max_vel>
              <min_depth>0</min_depth>
            </ode>
            <bullet>
              <split_impulse>1</split_impulse>
              <split_impulse_penetration_threshold>-0.01</split_impulse_penetration_threshold>
              <kp>1e+13</kp>
              <kd>1</kd>
            </bullet>
          </contact>
        </surface>
    <static>1</static>
    <allow_auto_disable>1</allow_auto_disable>
Asked by percyliu_ on 2017-07-27 02:52:28 UTC
Would you mind posting the sdf of the cuboid? Does it have a collision element? http://sdformat.org/spec?ver=1.6&elem=collision
Asked by sloretz on 2017-07-27 09:40:26 UTC
Thank you. I've already posted the code.
Asked by percyliu_ on 2017-07-27 19:21:27 UTC
Ok I just tested this box and it worked perfectly for me.
Here you have the video response of how to do this test: Here I leave the main things I used to test it and some system information:
Information System:
Ubuntu 14.04.5 trusty ROS Version: indigo Gazebo 7.4.0
I Created a Gazebo model with the code you posted: C:\fakepath\model.sdf And a "model.config"
Then I spawned it in a empty world: C:\fakepath\model.world
And then I used a simple spawn launch for sdfs: C:\fakepath\spawn_testobject_sdf.launch C:\fakepath\spawn_sdf.launch
I then used one robot I had to test the interaction, and it intercated perfectly, it didn't go through.
We need more info to get to the solution but, definetly is not the box. The problem may come from some world parameters, or from the robot itself. Maybe the meshes of the feet are to simple or don't have enough subdivisions in the mesh. Maybe its ultra heavy or maybe its something configured that avouds colisions with certain elements.
Asked by Duckfrost on 2017-08-01 04:19:30 UTC
