How to get a ModelPtr from a VisualPlugin
Let's assume I have a model with a 'body' base link that connected to some link 'link1' through a fixed joint. Now I attach a visual to 'link1' with an associated VisualPlugin. Let's say that I want to adjust the pose of this visual by listening to a transform coming form ROS, but the transform itself is prefixed by the model name, which by convention matches the name of the gazebo model to which the link is attached.
More specifically for the code snippet below, how do I extract a ModelPtr for the base link to which the Visual is attached, using only the VisualPtr being passed into the Load(...) callback.
// Gazbeo includes
#include <gazebo/rendering/rendering.hh>
namespace gazebo {
class GazeboVisualPluginOptions : public VisualPlugin {
public:
GazeboVisualPluginOptions() {}
virtual ~GazeboVisualPluginOptions() {}
protected:
// Called when the plugin is loaded into the simulator
void Load(rendering::VisualPtr visual, sdf::ElementPtr sdf) {
physics::ModelPtr model = ???
GZ_REGISTER_VISUAL_PLUGIN(GazeboVisualPluginOptions)
Asked by Andrew Symington on 2017-08-03 12:59:24 UTC
Visual plugins run in the rendering thread, while physics::Model
s are in the physics thread.
When running Gazebo, if you have cameras, you'll have 2 rendering threads, one in the gzserver
process and another on the gzclient
process.
The rendering thread which runs in the server, in theory could use the ignition::physics::get_world
call to get the physics::WorldPtr
and then you can use World::GetModel
to get the model pointer.
If all you're interested in is the model pose though, I would recommend not mixing rendering and physics and instead either subscribing to the ROS transform within your visual plugin, or subscribing to the Gazebo topic ~/pose/local/info
Asked by chapulina on 2017-08-03 13:23:58 UTC
Thanks! I see the constraint now. The solution I am currently using is a ModelPlugin that uses the gazebo transport to send a visual message to ~/visual, which toggles the transparency. However, this has two limitations: (1) I would also like to configure the visual to not be seen by camera sensors, but I don't believe SetVisibilityFlags(...) is supported by msgs::Visual, and (2) the way URDF bundles links joined by fixed joints together makes Visual names awful to lookup.
Asked by Andrew Symington on 2017-08-03 14:06:20 UTC
