Gazebo system plugin tutorial problem: no frames saved
I am doing gazebo system plug in tutorial ( link )
After running the plugin, I suppose to have several pictures saved in /tmp/gazebo_frames directory. However, when I checked, I didn't even have such directory, let alone the frames.
Anyone has the same problem with me? What is the solution?
Side question: I know that gzserver
is to run the gazebo server, but what does the & modifier do in gzserver &
command?
Asked by alienmon on 2017-08-14 02:42:35 UTC
had the same issue... Just forgot the export part, that wasn't in this part of the tutorial :
export GAZEBO_PLUGIN_PATH=${GAZEBO_PLUGIN_PATH}:~/gazebo_plugin_tutorial/build/
that solved the problem for me . . .
Asked by guyhaume25 on 2018-06-27 08:59:59 UTC
what gazebo version are you using? I tested with gazebo7 and it seems to work fine.
The & puts gzserver process in the background, freeing the terminal to run another proces, i.e. gzclient
Asked by iche033 on 2017-08-14 19:50:23 UTC
@iche033 I'm using gazebo 7 on Ubuntu 16, ROS Kinetic. You found the frames in /tmp/gazebo_frames folder?
Asked by alienmon on 2017-08-14 22:12:01 UTC
yes I see the images in /tmp/gazebo_frames. When running the gzclient command with -g to load the plugin, add --verbose and see if that prints out any error messages
Asked by iche033 on 2017-08-15 11:53:49 UTC
