Does the gripper tag still work in Gazebo 7?
I'm trying to use the old hacky way for gripping in Gazebo 7/ROS Kinetic, as described in this thread.
I've had no success with the object attaching to the gripper. Is gazebo still supposed to attach the object to the gripper?
I've got a dual gripper configuration - the surface properties are as follows:
<gazebo reference="${name}_link">
<mu1>1.0</mu1>
<mu2>1.0</mu2>
<minDepth>0.005</minDepth>
<kp>3e2</kp>
<kd>1</kd>
<maxContacts>5</maxContacts>
Since the gripper fingers are effort controlled, I've had to reduce the kp value considerably to have sustained stable contacts. My usage of the gripper hack looks as follows:
<gazebo>
<gripper name="${name}_grasping">
<grasp_check>
<attach_steps>5</attach_steps>
<detach_steps>10</detach_steps>
<min_contact_count>1</min_contact_count>
</grasp_check>
<gripper_link>${name}_left_gripper_link</gripper_link>
<palm_link>{name}_right_gripper_link</palm_link>
</gripper>
Any advice to get this working would be appreciated. Thanks!
Asked by piyushk on 2017-08-24 17:26:40 UTC
The answer is yes! The gripper hack works as expected in Gazebo 7/ROS Kinetic.
I messed up palm_link
and didn't realize it. It should have read <palm_link>${name}_right_gripper_link</palm_link>
- I forgot the $ sign, and xacro wasn't expanding it.
Asked by piyushk on 2017-08-24 17:51:52 UTC
As far as you know is this the only means of grasping in Gazebo? Does your implementation require the 5--15 seconds mentioned elsewhere to attach the object? (I'm struggling with simulated grasping. http://answers.gazebosim.org/question/20217/physics-problem-with-simple-movement-of-grasped-object/)
Asked by raequin on 2018-08-17 11:35:09 UTC
It seems that grasping works fine in this simulation (https://ieeexplore.ieee.org/document/7090732/) without needing the gripper tag.
Asked by raequin on 2018-08-17 11:40:43 UTC
