why the gpu_ray sensor number in a world is limited ?
Hello all,
I am trying to accurately simulate a velodyne sensor with 16 plains :
As the needed angular resolution is 0.1deg and the rotation rate is about 10Hz,
I attempting to achieve this by creating a plugin that reads data fro 36 rotating, ray sensors, that are tilted on the side.
If i use regular ray sensors, things are working fine. But if i switch to gpuray, and use more than 16 gpuray sensors some of them do not produce any data, and if i use more than 24 sensors gazebo crashes
I am using : Gazebo 8 (also happens with Gazebo 5 and 7) Ubuntu 16.04 CPU : Xeon(R) E5-1620 v3 @ 3.50GHz × 8 RAM : 16G GPU : Nvidea Gefoce GTX1080 (also happens with Quadro K2200)
If anybody have any idea, please, give me some direction
(as sloretz suggested i have also created a Bittbucket issue)
Asked by dmeltz on 2017-08-31 09:41:04 UTC
This sounds like a bug. Would you mind opening an issue on https://bitbucket.org/osrf/gazebo ?
Asked by sloretz on 2017-08-31 10:00:54 UTC
