not found problem on cmake -DCMAKE_BUILD_TYPE=DEBUG ../
asked 2013-03-10 08:49:57 -0500
updated 2013-03-17 17:45:46 -0500
nkoenig gravatar image
mohsen@mohsen-ThinkPad-R500:~/gazebo-1.4.0/build$ cmake -DCMAKEBUILDTYPE=DEBUG ../
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Gazebo version 1.4.0
-- Found CPack generators: DEB
-- Found Doxygen: /usr/bin/doxygen
====== Finding 3rd Party Packages ======
-- Operating system is Linux
-- checking for module 'freeimage>='
Must specify package names on the command line
--   package 'freeimage>=' not found
--   freeimage.pc not found, trying freeimage_include_dir and freeimage_library_dir flags.
--   Looking for FreeImage.h - found
--   Looking for libfreeimage - found
-- Found PROTOBUF: /usr/lib/libprotobuf.so
-- Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so
-- Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /usr/lib/x86_64-linux-gnu/libX11.so
-- Found OpenGL: /usr/lib/libGL.so
-- checking for module 'libcurl'
--   found libcurl, version 7.21.6
-- checking for module 'libprofiler'
--   package 'libprofiler' not found
-- Looking for libprofiler - not found
-- checking for module 'libtcmalloc'
--   package 'libtcmalloc' not found
-- Looking for libtcmalloc - not found
-- checking for module 'CEGUI'
--   found CEGUI, version 0.6.2
-- checking for module 'CEGUI-OGRE'
--   package 'CEGUI-OGRE' not found
-- Looking for CEGUI, found
--  CEGUI-OGRE not found, opengl GUI will be disabled.
-- checking for module 'bullet'
--   package 'bullet' not found
-- Looking for tinyxml.h - found
-- Looking for libtar.h - found
-- checking for module 'tbb'
--   found tbb, version 3.0+r018
-- checking for module 'OGRE-RTShaderSystem>=1.7.1'
--   found OGRE-RTShaderSystem, version 1.7.3
-- checking for module 'OGRE>=1.7.1'
--   found OGRE, version 1.7.3
-- checking for module 'OGRE-Terrain'
--   found OGRE-Terrain, version 1.7.3
-- checking for module 'libswscale'
--   found libswscale, version 2.0.0
-- checking for module 'libavformat'
--   found libavformat, version 53.3.0
-- checking for module 'libavcodec'
--   found libavcodec, version 53.6.0
--  urdfdom_headers not found, urdf parser will not be built.
--  urdfdom not found, urdf parser will not be built.
--  console_bridge not found, urdf parser will not be built.
-- checking for modules 'playercore>=3.0;playerc++'
--   package 'playercore>=3.0' not found
--  Player not found, gazebo plugin for player will not be built.
-- checking for module 'gts'
--   package 'gts' not found
--  GNU Triangulation Surface library not found - Gazebo will not have CSG support.
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found.
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found.
-- Found Qt4: /usr/bin/qmake (found version "4 ...
(more)
What is exactly the problem? There are some build warnings but nothing critical. I would recommend to install ogre support.
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2013-03-13 11:46:46 -0500 )edit
tnx :) do you have any direct link to0 install ogre?
Mohsen Hk gravatar imageMohsen Hk ( 2013-03-13 17:06:57 -0500 )edit
looks like you are running 1.4, so see the Compiling from Source section on this page: http://gazebosim.org/wiki/1.4/install
iche033 gravatar imageiche033 ( 2013-03-14 02:26:27 -0500 )edit
answered 2013-07-23 19:21:05 -0500
scpeters gravatar image
Answered in comments.
Asked: 2013-03-10 08:49:57 -0500
Seen: 1,540 times
Last updated: Jul 23 '13
