How to add a mode which is downloaded to the world by add <uri>model:</uri>
I try to compile the world about UAV, I downloaded the SDF file, and I can insert this model into gazebo. When I try to compile the .world file, I add the .sdf and .config to the same file with the .world. I and the model to the world by using
What should I do to add the model to the world?
Asked by Ji Cai on 2017-09-09 11:05:47 UTC
Just one clarification, are you trying to insert the model from the database: https://bitbucket.org/osrf/gazebo_models/src/default/parrot_bebop_2 or a custom version of it? Could you update your question with the error you see and the structure of the folders where the models are located?
Asked by chapulina on 2017-09-09 11:16:00 UTC
