Unable to use ur5_joint_limited_robot.urdf.xacro
For a master assignment I have to use the UR5 to build Duplo structures. I already have the UR5 running on moveit.rviz and gazebo (https://github.com/ros-industrial/universal_robot/blob/indigo-devel/README.md). But, now I need to build these file structures myself without using moveit, according to my teacher. Altough whenever I want to test if the path is configured correctly, by running gazebo from terminal (according to this tutorial, http://gazebosim.org/tutorials?tut=ros_roslaunch#CreatingyourownGazeboROSPackage). I can find the UR5 but, whenever I click on it gazebo gives me these errors:
Error: Failed to build tree: child link [baselink] of joint [worldjoint] not found at line 226 in /build/urdfdom-UJ3kd6/urdfdom-0.4.1/urdf_parser/src/model.cpp
Error [parser_urdf.cc:3408] Unable to call parseURDF on robot model
Error [parser.cc:309] parse as old deprecated model file failed.
How can I get it to spawn correctly?
Thanks in advance!
Edwin
Asked by EdwinvanEmmerik on 2017-09-09 14:42:21 UTC
