Apply force to a joint with Ros?
Hello Guys,
is it possible to apply a force to an joint with Ros?
I created an arm and before i start with ros joint controller i want to try something easier.
Asked by Baumboon on 2017-10-25 07:23:38 UTC
Yes, the easiest way to do that (to my knowledge) would be to write a brief joint plugin which you can then send commands to via ROS
Asked by josephcoombe on 2017-10-25 13:50:57 UTC
can i do this like they describe it in : http://gazebosim.org/tutorials?cat=guided_i&tut=guided_i5?
Asked by Baumboon on 2017-10-26 05:04:37 UTC
^ Yes, that's what you want to do.
Asked by josephcoombe on 2017-10-26 18:09:04 UTC
there is also the ~/apply_joint_effort ros service mentioned in the ROS communication tutorial, though I've not tried it before: http://gazebosim.org/tutorials?tut=ros_comm&cat=connect_ros
Asked by iche033 on 2017-10-30 18:16:25 UTC
