Blender model import STL and Dae problem with link names
Hello guys,
today i imported some blender models all got no link name. With no link name i can“t do anything with them.
Can u tell me why they got no link name?
Please help me
Asked by Baumboon on 2017-10-25 09:04:41 UTC
A Collada or STL file by itself won't give you Gazebo links, you must put each "node" of your mesh into a separate <link> in your model's SDF description.
I recommend you first get familiar with links, joints, collisions and visuals in Gazebo. This tutorial should give you a good idea.
After you've understood those concepts, let's go through an example of creating separate links for each node on a COLLADA mesh.
Let's take the zephyr_delta_wing model as an example.
  1. Open the collada file and look for <node> elements (they should be inside <visual_scene>. This is what they look like for the Zephyr wing:
    <node name="EnvironmentAmbientLight">
    </node>
    <node id="node-Wing_Bone" name="Wing_Bone">
      <node id="node-Wing" name="Wing">
      </node>
      <node id="node-Flap_Left_Bone" name="Flap_Left_Bone">
        <node id="node-Flap_Left" name="Flap_Left">
        </node>
      </node>
      <node id="node-Flap_Right_Bone" name="Flap_Right_Bone">
        <node id="node-Flap_Right" name="Flap_Right">
        </node>
      </node>
      <node id="node-Prop_Bone" name="Prop_Bone">
        <node id="node-Prop" name="Propeller">
        </node>
      </node>
    </node>
  2. On our SDF file, where we reference the COLLADA file, if we don't choose a submesh, all the nodes will be used together. But if we want only one node, we can refer to its name. For example, for the propeller link we have the following:
    <link name="propeller">
          <mesh>
            <uri>model://zephyr_delta_wing/meshes/wing.dae</uri>
            <submesh>
              <name>Propeller</name>
              <center>true</center>
            </submesh>
          </mesh>
  3. Note how each link of that model has a different submesh and how they can be moved independently in simulation:
image description
Asked by chapulina on 2017-10-25 10:06:02 UTC
So if i understand u right i can use whole mesh and after i import it as dae i can use the submesh to make me a proper model with correct links and joints ? I just need to set the correct reference to the nodes?
Asked by Baumboon on 2017-10-26 04:24:25 UTC
Correct. And make sure the parts you want to separate are different nodes before you export to collada.
Asked by chapulina on 2017-10-26 12:44:58 UTC
