turtlebot sim crashes on subscribing to any topic
First I run the turtlebot run launch file from the terminal:
$ roslaunch turtlebot_gazebo turtlebot_world.launch
Then in a new terminal:
$ rostopic echo /scan
As soon as I subscribe to the /scan topic i get the following error:
gzserver: /build/ogre-1.9-mqY1wq/ogre-1.9-1.9.0+dfsg1/OgreMain/src/OgreRenderSystem.cpp:546: virtual void Ogre::RenderSystem::setDepthBufferFor(Ogre::RenderTarget*): Assertion `bAttached && "A new DepthBuffer for a RenderTarget was created, but after creation" "it says it's incompatible with that RT"' failed.
Aborted (core dumped)
[gazebo-1] process has died [pid 21624, exit code 134, cmd /opt/ros/kinetic/lib/gazebo_ros/gzserver -e ode /opt/ros/kinetic/share/turtlebot_gazebo/worlds/playground.world __name:=gazebo __log:=/home/pranav/.ros/log/f18cc0fc-ccc2-11e7-9a30-9cb6d0e527e7/gazebo-1.log].
log file: /home/pranav/.ros/log/f18cc0fc-ccc2-11e7-9a30-9cb6d0e527e7/gazebo-1*.log
Asked by inani47 on 2017-11-19 17:49:13 UTC
Which operative system, graphic card, Gazebo vesion and ROS version are you using? Are you running it from a virtual machine?
Asked by Jose Luis Rivero on 2017-11-23 15:57:24 UTC
I'm having the same issue, using Ubuntu 16.04 on ROS kinetic using Gazebo version 7.0.0 on a VirtualBox
Asked by Void on 2018-05-09 12:15:55 UTC
