Is there a memory leak when changing visual color from model plugin?
asked 2017-11-29 04:27:14 -0500
elcymon gravatar image
updated 2017-11-29 04:32:28 -0500
I am trying to change the visual of a mobile robot based on the state of the robot. Though this works (i.e. the visual of the model changes to the desired color), the gazebo simulator starts to freeze. When I delete the section of code that changes the model's colour, gazebo simulation works as normal (i.e. without freezing).
Please what am I doing wrong here?
This is the code snippet:
        gazebo::common::Color newColor(0.0,1.0,0.0,1.0);
        msgs::Color *homColMsg = new gazebo::msgs::Color(gazebo::msgs::Convert(newColor));
        msgs::Color *homDiffMsg = new gazebo::msgs::Color(*homColMsg);
        gazebo::physics::LinkPtr link = this->model->GetLink("chassis");
        msgs::Visual visMsg = link->GetVisualMessage("visual");
        msgs::Material *materialMsg = visMsg.mutable_material();
        materialMsg->clear_ambient();
        materialMsg->clear_diffuse();
        visMsg.set_name(link->GetScopedName());
        visMsg.set_parent_name(this->model->GetScopedName());
        materialMsg->set_allocated_ambient(homColMsg);
        materialMsg->set_allocated_diffuse(homDiffMsg);
        this->pub_visual->Publish(visMsg);
The inspiration for this approach is from: handsim implementation
Interesting that on Handsim the link name is used on the visual message, I'd expect that to be the visual name. i.e. `model::link::visual` instead of `model::link`
chapulina gravatar imagechapulina ( 2017-11-29 10:37:26 -0500 )edit
I changed it to 'model::link::visual' and it works fine now! Thanks.
elcymon gravatar imageelcymon ( 2017-11-29 10:57:46 -0500 )edit
Great! I added an answer so feel free to accept it and close the question ;)
chapulina gravatar imagechapulina ( 2017-11-29 11:05:17 -0500 )edit
answered 2017-11-29 11:03:09 -0500
As mentioned on the comments, the solution was to use the scoped visual name instead of the scoped link name.
Asked: 2017-11-29 04:27:14 -0500
Seen: 191 times
Last updated: Nov 29 '17
