Relocalisation with Turtlebot on a Map?
Hello guys,
i uses ros kinetic with gazebo 7.0. I have following problem:
I run a turtlebot in a world i created. Now i want to drive into an object with my turtlebot to see whether i can push it or not. The main problem here is when i drove into the object for 1-2 seconds i got a big deviation on my map.
Now i think the problem with the map deviation can be solved if i can relocalisate my Robot.
To understand what kind of map i use here are my commands for mapping:
Building map:
roslaunch turtlebot_gazebo gmapping_demo.launch
Starting map:
roslaunch turtlebot_gazebo amcl_demo.launch map_file:=/home/<user_name>/turtlebot_custom_maps/tutorial.yaml
So my question is, is there a way to relocalise the Robot manually if there is a too big deviation from map position to real position. Or is there a map that fits better for the requirement i needed?
Asked by Baumboon on 2017-12-06 06:39:47 UTC
