gazebo crashing when lauching turtlebot ( docker container )
I installed a docker container with gazebo
source: https://github.com/osrf/docker_images...
After this i installed ros kinetic on the container. I want to launch robots ( turtlebot in this case ) so they go in gazebo.
When i run roslaunch turtlebotgazebo turtlebotworld.launch i get the next error.
[gazebo-2] process has died [pid 21045, exit code 255, cmd /opt/ros/kinetic/lib/gazebo_ros/gzserver -e ode /opt/ros/kinetic/share/turtlebot_gazebo/worlds/playground.world __name:=gazebo __log:=/root/.ros/log/e3d818a2-db5f-11e7-b4d8-0242ac110002/gazebo-2.log]. log file: /root/.ros/log/e3d818a2-db5f-11e7-b4d8-0242ac110002/gazebo-2*.log process[mobile_base_nodelet_manager-5]: started with pid [21117] process[cmd_vel_mux-6]: started with pid [21130] process[bumper2pointcloud-7]: started with pid [21161] process[robot_state_publisher-8]: started with pid [21244] process[laserscan_nodelet_manager-9]: started with pid [21293]
Any help on how to fix this is really appreciated
Asked by benjaminklingeleers on 2017-12-07 10:25:03 UTC
some hints to debug the problem: does the docker image defines a DISPLAY? what is the output of echo $DISPLAY? Let's start first by trying to run gazebo alone wihtout ROS. What does gazebo --verbose display? Please edit the answer and add the information.
Asked by Jose Luis Rivero on 2017-12-07 13:29:56 UTC
ECho $display returns :0
Gazebo verbose : [Err] [master.cc:96] EXCEPTION: Unable to start server [bind: Address already in use]. There is probably another Gazebo process running.
However, when i do gzclient it launches a gazebo client what works.
When i run ps ax i see gzserver running with PID 1. Even when i do kill -9 1 its still there next time.
Edit : i exported the gazebo master ip and gazebo master uri to 127.0.0.1:11345
now i get the next output : https://pastebin.com/HjemSSPW
Asked by benjaminklingeleers on 2017-12-08 02:39:40 UTC
Even tho the verbose process works i still cant launch
Asked by benjaminklingeleers on 2017-12-08 03:10:06 UTC
looks like there is a gzserver process floating around somehow. I would start by debugging where (in the container or in the host), kill it and launch the process again until getting it working or a different error.
Asked by Jose Luis Rivero on 2017-12-28 18:28:41 UTC
