Movement of smaller links affecting the whole body
Hi, I've solved the problem of removing the gravity from the gripper model, but now I have another problem. When I try to move the grippers claws, whole body starts to move, even if it's not specified at the joint. How can I modify the base link, so it stays rigid while the claws open and close, and also, I need the possibility to move it up and down (and possibly, rotate it)? The models code is in the link above. Here is the behavior that I want to get rid of:
