Robot doesn't take a turn to face the goal in Gazebo.
I have created a custom robot model in Gazebo, with a Skid Steer drive controller plugin. I tried this video, but my robot doesn't take any turn, and it's moving to a straight line for ever. This is the code from the video :
#! /usr/bin/env python
import rospy
from nav_msgs.msg import Odometry
from tf.transformations import euler_from_quaternion
from geometry_msgs.msg import Point, Twist
from math import atan2
x = 0.0
y = 0.0
theta = 0.0
def newOdom (msg):
global x
global y
global theta
x = msg.pose.pose.position.x
y = msg.pose.pose.position.y
rot_q = msg.pose.pose.orientation
(roll, pitch, theta) = euler_from_quaternion ([rot_q.x, rot_q.y, rot_q.z, rot_q.w])
rospy.init_node ("speed_controller")
sub = rospy.Subscriber("/odom", Odometry, newOdom)
pub = rospy.Publisher("/cmd_vel",Twist, queue_size=1)
speed = Twist()
r = rospy.Rate(4)
goal = Point ()
goal.x = 100
goal.y = 100
while not rospy.is_shutdown():
inc_x = goal.x - x
inc_y = goal.y - y
angle_to_goal = atan2 (inc_y, inc_x)
if abs(angle_to_goal - theta) > 0.1:
speed.linear.x = 0.0
speed.angular.z = 1.0
else:
speed.linear.x = 0.5
speed.angular.z = 0.0
pub.publish(speed)
r.sleep()
This is the URDF parts for the wheels:
<joint name="front_axle_to_front_left_wheel" type="continuous">
<parent link="front_axle"/>
<child link="front_left_wheel"/>
<origin rpy="0 0 0" xyz="1.0000000e-04 -1.0000000e-04 -1.78000000e-00"/>
<axis xyz="0 0 -1.0000000e+00"/>
<limit effort="-1.0" lower="-1.79769e+308" upper="1.79769e+308" velocity="-1.0"/>
<link name="front_left_wheel">
<mass value="0.1"/>
<origin rpy="0 0 0" xyz="0 0 0"/>
<inertia ixx="0" ixy="0" ixz="0" iyy="0" iyz="0" izz="0"/>
<cylinder length="0.87" radius="1.275"/>
<joint name="front_axle_to_front_right_wheel" type="continuous">
<child link="front_right_wheel"/>
<origin rpy="0 0 0" xyz="1.0000000e-04 1.0000000e-04 1.78000000e-00"/>
<axis xyz="0 0 1.0000000e+00"/>
<link name="front_right_wheel">
<mass value="0.1"/>
<joint name="back_axle_to_back_left_wheel" type="continuous">
<parent link="back_axle"/>
<child link="back_left_wheel"/>
<origin rpy="0 0 0" xyz="-1.0000000e-04 -1.0000000e-04 -1.78000000e-00"/>
<link name="back_left_wheel">
<mass value="0.1"/>
<joint name="back_axle_to_back_right_wheel" type="continuous">
<child link="back_right_wheel"/>
<origin rpy="0 0 0" xyz="-1.0000000e-04 -1.0000000e-04 1.78000000e-00"/>
<link name="back_right_wheel">
<mass value="0.1"/>
And the Skid Steer plugin:
<gazebo>
<plugin name="skid_steer_drive_controller" filename="libgazebo_ros_skid_steer_drive.so">
<updateRate>100.0</updateRate>
<leftFrontJoint>front_axle_to_front_left_wheel</leftFrontJoint>
<rightFrontJoint>front_axle_to_front_right_wheel</rightFrontJoint>
<leftRearJoint>back_axle_to_back_left_wheel</leftRearJoint>
<rightRearJoint>back_axle_to_back_right_wheel</rightRearJoint>
<wheelSeparation>3.33</wheelSeparation>
<wheelDiameter>27.4</wheelDiameter>
<robotBaseFrame>link_name</robotBaseFrame>
<torque>21</torque>
<topicName>cmd_vel</topicName>
<broadcastTF>false</broadcastTF>
<covariance_x>0.0001</covariance_x>
<covariance_y>0.0001</covariance_y>
<covariance_yaw>0.01</covariance_yaw>
Asked by moshimojo on 2017-12-29 15:57:27 UTC
