Gazebo with ros kinetic not starting up
Hi every time i try to run gazebo i get the following error:
X Error of failed request: BadValue (integer parameter out of range for operation) Major opcode of failed request: 154 (GLX) Minor opcode of failed request: 3 (X_GLXCreateContext) Value in failed request: 0x0 Serial number of failed request: 23 Current serial number in output stream: 24
I have an NVidia GeForce 1080 graphics card that should be capable of handling 3D. Please could you help me with this issue? I am running ROS kinetic.
Asked by rohitsub11 on 2018-01-09 23:38:58 UTC
Posting what command you used for running your Gazebo simulation may help.
Asked by samisnotinsane on 2018-01-11 12:03:55 UTC
What graphic driver is installed on your system?
Asked by wentz on 2018-01-15 07:33:33 UTC
