Launch robot using sdf file
I have a urdf robot model. To make the ros gazebo bumper plugin work, I had to convert the urdf file to the sdf format and make some custom changes.
Now I need to load updated sdf robot model instead of the urdf model.
Launch file:
<launch>
<arg name="world_file" default="$(env SUMMIT_WORLD_CIRCUIT1)"/>
<arg name="use_sim_time" value="true"/>
<arg name="debug" value="false"/>
<arg name="world_name" value="$(arg world_file)"/>
<!-- summit_xl_control launch file -->
<include file="$(find summit_xl_control)/launch/summit_xl_omni_control.launch" />
<!-- launch pad -->
<include file="$(find summit_xl_pad)/launch/summit_xl_pad.launch" />
<!-- Load the URDF into the ROS Parameter Server -->
<param name="robot_description"
command="$(find xacro)/xacro.py '$(find summit_xl_description)/robots/summit_xl_omni.urdf.xacro'" />
<!-- Load the SDF into the ROS Parameter Server -->
<param name="robot_sdf" textfile="/home/ruettinger/Dokumente/Bachelorarbeit/Code/ba_ws/src/summit_xl_common/summit_xl_description/robots/summit_xl_omni.sdf" />
<!-- Call a python script to the run a service call to gazebo_ros to spawn a SDF robot -->
<node name="sdf_spawner" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen"
args="-sdf -model summit_xl
-file /home/ruettinger/Dokumente/Bachelorarbeit/Code/ba_ws/src/summit_xl_common/summit_xl_description/robots/summit_xl_omni.sdf"/>
The launch file doens't work.
When I load the robot model by hand, the visualization is buggy and I get the following warning.
rosrun gazebo_ros spawn_model -file /home/*****/summit_xl_omni.sdf -sdf -model test -y 0.0 -x -0.0
[WARN] [1516896999.247439, 0.260000]: Controller Spawner couldn't find the expected controller_manager ROS interface.
Does anybody know how to properly call a sdf file which was converted from a urdf file per hand?
Asked by Feynman on 2018-01-25 11:31:41 UTC
