GPS doesn't show true data when moving in Gazebo
Hello everyone!
I have installed Gazebo 8 with ROS Kinetic on Ubuntu 16.04 LTS. I have built a custom robot model in Gazebo and added a libhectorgazeborosgps plugin. Also attached a basefootprint on the robot. But when i run rostopic echo /fix
and rostopic echo /fix_velocity
, none of them shows true data.
Do i need to build a map first? I tried to build a map through turtlebot tutorials, but i see no map on Rviz either. I have been searching for a long time, but i can't find a solution to the problem. Any suggestions will be helpful!
Thank you, moshimojo
Asked by moshimojo on 2018-01-31 05:01:50 UTC
