Can actors be detected by lasser sensor?
I'm trying to detect some actors using the lasser sensor provided by gazebo, but it never collides with the model, is there a way to do it?
Asked by BattleCroissant on 2018-02-06 06:20:57 UTC
You need to use a gpu_ray sensor, not a ray sensor. Unfortunately, there's no example of a GPU ray sensor in the model database, but you can try this world:
image description
Asked by chapulina on 2018-02-06 14:00:15 UTC
I had the same issue and the solution bellow works fine.
The only thing is that you must change the SDF/URDF file of your sensor.
Asked by klapetos on 2018-02-10 13:35:01 UTC
