Why does the velocity limit also limit effort?
A low <limit> velocity </limit> in the URDF also limits the effective effort a joint can apply.
I am loading robot arms from a urdf xacro with a hardwareinterface/EffortJointInterface using a roslaunch script. I am spawning an effortcontrollers/JointPositionController for each joint. I am commanding the arms "straight out":
With a high effort limit (3000) and low velocity limit (20) on each joint the arms droop: image description
With the same effort limit but a larger velocity limit (50) the arms successfully reach their goal position: image description
My best guess is that the controller outputs a large effort which leads to a large velocity, and this velocity is clipped before gravity terms are added.
i.e.
vel_limit(controller) + gravity = 0
instead of
vel_limit(controller + gravity) = "upwards motion"
Asked by bsaund on 2018-02-15 12:56:09 UTC
Is the argument paused false when you bring up the empty world?
Asked by lakehanne on 2018-09-10 08:17:11 UTC
