Robot Keep bouncing up and down
Hello everyone,
I've been through a pair of answers on this forum concerning robot bouncing but found nothing that helped me :/ On a side note I'm relatively new to ROS and GAZEBO so I might have done steps wrong. I join the XML code hoping someone will find why my robot keep boucing following the Y axis.
Sincerely yours, Anonymate passionate
//mybot.xacro
<?xml version='1.0'?>
<collision>
<origin xyz="-0.04 0 0.048" rpy="0 0 0"/>
<mesh filename="package://mybot_description/meshes/test.dae"/>
<visual>
<visual name='chassis_visual4'>
<origin xyz="${Xorigin} ${Yorigin} ${Zorigin}" rpy=" 0 0 0"/>
<box size="${Xsize} ${Ysize} ${Zsize}"/>
<visual name='chassis_visual5'>
<origin xyz="${Xorigin} ${-1*Yorigin} ${Zorigin}" rpy=" 0 0 0"/>
<visual name='caster_front_visual1'>
<origin xyz="0.09 -0.06 0.0245" rpy=" 0 0 0"/>
<sphere radius="0.007"/>
<collision name='caster_front_collision2'>
<origin xyz="0.09 0.06 0.0245" rpy=" 0 0 0"/>
<surface>
<friction>
<ode>
<mu>0</mu>
<mu2>0</mu2>
<slip1>1.0</slip1>
<slip2>1.0</slip2>
</ode>
</friction>
</surface>
<visual name='caster_front_visual2'>
<!--origin xyz="0.1 0.13 0.1" rpy="0 1.5707 1.5707"/-->
<!--origin xyz="0.1 -0.13 0.1" rpy="0 1.5707 1.5707"/-->
<visual>
<mesh filename="package://mybot_description/meshes/hokuyo.dae"/>
<mass value="1e-5" />
<inertia ixx="1e-6" ixy="0" ixz="0" iyy="1e-6" iyz="0" izz="1e-6" />
Asked by BlooDShifT on 2018-02-20 11:35:32 UTC
I think the formatting in your question got messed up (parts in code and parts aren't)!
Would be useful if you edited your question to include the answers that did not work for you and(or) what you have tried so far to fix this bouncing.
Asked by josephcoombe on 2018-02-21 09:51:51 UTC
