How to choose the Gaussian noise of a Sensor?
I am using Velodyne VLP16 Lidar at my simulations. I found the plugin below from here;
    <plugin name="gazebo_ros_laser_controller" filename="libgazebo_ros_velodyne_laser.so">
      <topicName>${ros_topic}</topicName>
      <frameName>${name}_frame</frameName>
      <min_range>0.45</min_range>
      <max_range>130.0</max_range>
      <gaussianNoise>0.008</gaussianNoise>
And I wonder why Gaussian Noise is set to 0.008 and how can it be measured?
This is the sensor specifications; image description
Asked by aybakana1994 on 2018-03-17 11:53:21 UTC
I'm not entirely sure about this but if the accuracy of your sensor is +/- 3cm then you would set the gaussianNoise parameter as 0.03 as this parameter sets the maximum deviation from the actual value.
Asked by Raskkii on 2018-03-19 03:56:58 UTC
