Strange wall appears to PointCloud in Rviz when using block_laser plug-in.
Hi friends,
I need your help about a wall displayed in Rvis when using blocklaser GAZEBO plug-in.
I placed a sensor with blocklaser plugin-in in URDF file as below.
The purpose was to check how it works when the sensor detects a cube.
When I displayed a PointCloud on Rviz, the result looks almost perfect. However, I found a strange huge wall far away.
I didn't place any obstacle there, but it looks like displaying the max distance which I inputted in URDF file.
For my understanding, PointCloud is displaying the reflection from the obstacle or ground. So, this result doesn't make sense to me.
Could any one please tell me what is this wall and how to delete from PointCloud?
Thanks,
ROS:kinetic
GAZEBO:7.11
GAZEBO looks like
Rviz looks like
URDF file is as below
<?xml version="1.0"?>
<link name="base_link">
<visual>
<origin xyz="-4.7 0 2.2" rpy="0 0 0"/>
<box size="9.4 4.2 4.4"/>
<collision>
<origin xyz="-4.7 0 2.2" rpy="0 0 0" />
<origin xyz="0 0 2.2" rpy="0 0 0" />
<mass value="0.03" />
<inertia ixx="1.0" ixy="0.0" ixz="0.0"
iyy="1.0" iyz="0.0"
izz="1.0" />
<!-- ground -->
<link name="base_footprint"/>
<joint name="base_link_joint" type="fixed">
<parent link="base_footprint"/>
<child link="base_link"/>
<origin xyz="0 0 0"/>
<!-- cardboard box1 -->
<link name="cardboard_box">
<visual>
<origin xyz="8 0 0.25" rpy="0 0 0"/>
<box size="0.5 0.5 0.5"/>
<collision>
<origin xyz="8 0 0.25" rpy="0 0 0" />
<mass value="1.0" />
iyy="1.0" iyz="0.0"
izz="1.0" />
<joint name="cardboard_box_joint" type="fixed">
<child link="cardboard_box"/>
<!-- gazebo -->
<gazebo>
<robotNamespace>block_laser_test</robotNamespace>
<selfCollide>true</selfCollide>
<mu1 value="0.5" />
<mu2 value="0.5" />
<!-- Block laser sensor 1 -->
<link name="BLS_1_optical_frame" />
<link name="BLS_1_link">
<visual>
<box size="0.063 0.095 0.090"/>
<collision>
<mass value="1"/>
<inertia
iyy="1.0" iyz="0.0"
izz="1.0"/>
<joint name="BLS_1_base_joint" type="fixed">
<origin xyz="0 0 1.0" rpy="0 0 0"/>
<parent link="base_link"/>
<child link="BLS_1_optical_frame"/>
<joint name="BLS_1_joint" type="fixed">
<parent link="BLS_1_optical_frame"/>
<child link="BLS_1_link"/>
<!-- gazebo Block laser sensor 1 plugin -->
<gazebo reference="BLS_1_link">
<sensor type="ray" name="BLS_1_ir_sensor">
<pose>0.0 0.0 0.0 0.0 0.0 0.0</pose>
<update_rate>5</update_rate>
<ray>
<scan>
<horizontal>
<samples>650</samples>
<min_angle>${-65.0*M_PI/180.0}</min_angle>
<max_angle>${65.0*M_PI/180.0}</max_angle>
</horizontal>
<vertical>
<samples>80</samples>
<min_angle>${-8.0*M_PI/180.0}</min_angle>
<max_angle>${8.0*M_PI/180.0}</max_angle>
</vertical>
</scan>
<range>
<min>0.1</min>
<max>27.0</max>
</range>
<noise>
<type>gaussian</type>
<mean>0.0</mean>
<stddev>1</stddev>
</noise>
</ray>
<plugin name="BLS_1_link_controller" filename="libgazebo_ros_block_laser.so">
<topicName>scan_bls_1</topicName>
<updateRate>5</updateRate>
<frameName>BLS_1_optical_frame</frameName>
<alwaysOn>true</alwaysOn>
<material value="Gazebo/Green" />
</robot>
Asked by km60713 on 2018-03-20 15:11:21 UTC
