"WARNING: no messages received and simulated time is active. Is /clock being published?" - Force Torque
Running ubuntu 16.04, ROS kinetic, gazebo 7.
Trying to implement a force torque sensor model into a sawyer robot. Model was successfully implemented, but plugin doesn't publish any data. I get the warning from the question title. Yes, /clock is being published because calling "rostopic echo /clock" will show the simulation clock.
I've found solutions where it suggests to call the following: "rosparam set usesimtime false" and that hasn't fixed anything.
I've also seen solutions where it says to set the update_rate of the sensor to 0 in the robot.urdf. I can't try this solution because my sawyer.urdf does not contain the relevant section in the code where i would can set it the update rate to 0. the sensor package is based on xacro and i just include in the launch file of the sawyer robot.
any suggestions or advice would be much appreciated.
Asked by lr101095 on 2018-03-20 23:20:15 UTC
