ROS gazebo9 migration from gazebo7
Hello
I would like to use together Gazebo, ROS and citysim. Currently, I am using ROS-kinetic with Gazebo7. How to install Gazebo 9 instead Gazebo 7 without influence to ROS?
sudo apt-get install libgazebo9-dev
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
gazebo9 gazebo9-common gazebo9-plugin-base libavdevice-dev libavfilter-dev libavresample-dev libgazebo9 libignition-cmake-dev libignition-common libignition-common-dev libignition-fuel-tools libignition-fuel-tools-dev libignition-math4 libignition-math4-dev libignition-msgs libignition-msgs-dev libignition-transport4 libignition-transport4-dev libpostproc-dev libsdformat6 libsdformat6-dev libyaml-dev libzmq3-dev sdformat-sdf
Suggested packages:
gazebo9-doc libyaml-doc The following packages will be REMOVED:
gazebo7 gazebo7-common gazebo7-plugin-base libgazebo7 libgazebo7-dev libsdformat4 libsdformat4-dev ros-kinetic-desktop-full ros-kinetic-gazebo-dev ros-kinetic-gazebo-plugins ros-kinetic-gazebo-ros ros-kinetic-gazebo-ros-control ros-kinetic-gazebo-ros-pkgs ros-kinetic-simulators
The following NEW packages will be installed:
gazebo9 gazebo9-common gazebo9-plugin-base libavdevice-dev libavfilter-dev libavresample-dev libgazebo9 libgazebo9-dev libignition-cmake-dev libignition-common libignition-common-dev libignition-fuel-tools libignition-fuel-tools-dev libignition-math4 libignition-math4-dev libignition-msgs libignition-msgs-dev libignition-transport4 libignition-transport4-dev libpostproc-dev libsdformat6 libsdformat6-dev libyaml-dev libzmq3-dev
The following packages will be upgraded:
sdformat-sdf
Asked by 0xd1ma on 2018-03-27 11:16:42 UTC
Take a look at this: http://gazebosim.org/tutorials?tut=ros_wrapper_versions
It explains how to get a specific Gazebo version to work with ROS.
Asked by Raskkii on 2018-04-02 03:36:01 UTC
In my setup I switched from Gazebo 7 to Gazebo 9 with the following: sudo apt-get install ros-kinetic-gazebo9-ros*. Did you try that?
Asked by robotlab on 2018-04-13 12:44:04 UTC
