Windows Install: Install Folder doesn't exist after running Gazebo Configure commands
I am a complete noob to this. I am trying to install Gazebo on a Windows 10 PC. I execute this code:
**> cd ....\gazebo mkdir build cd build
if you want debug, run ..\configure Debug ..\configure nmake gzclient
nmake gzserver nmake install**
In a administrator command window in Visual Studio. The command runs and gives me some failures, and doesn't create the install folder. Not sure what I am doing wrong. Here is the CMakeOutput log:
**> The system is: Windows - 10.0.16299 -
AMD64 Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded. Compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.13.26128/bin/Hostx86/x64/cl.exe Build flags: Id flags:
The output was: 0 Microsoft (R) C/C++ Optimizing Compiler Version 19.13.26129 for x64 Copyright (C) Microsoft Corporation. All rights reserved.
CMakeCCompilerId.c Microsoft (R) Incremental Linker Version 14.13.26129.0 Copyright (C) Microsoft Corporation. All rights reserved.
/out:CMakeCCompilerId.exe CMakeCCompilerId.obj
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.exe"
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.obj"
The C compiler identification is MSVC, found in "C:/Program Files (x86)/gz-ws/gazebo/build/CMakeFiles/3.11.0/CompilerIdC/CMakeCCompilerId.exe"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded. Compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.13.26128/bin/Hostx86/x64/cl.exe Build flags: Id flags:
CMakeCXXCompilerId.cpp Microsoft (R) Incremental Linker Version 14.13.26129.0 Copyright (C) Microsoft Corporation. All rights reserved.
/out:CMakeCXXCompilerId.exe CMakeCXXCompilerId.obj
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.exe"
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.obj"
The CXX compiler identification is MSVC, found in "C:/Program Files (x86)/gz-ws/gazebo/build/CMakeFiles/3.11.0/CompilerIdCXX/CMakeCXXCompilerId.exe"
Determining if the C compiler works passed with the following output: Change Dir: C:/Program Files (x86)/gz-ws/gazebo/build/CMakeFiles/CMakeTmp
Run Build Command:"nmake" "/NOLOGO" "cmTCab5bc\fast" "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.13.26128\bin\HostX86\x86\nmake.exe" -f CMakeFiles\cmTCab5bc.dir\build.make /nologo -L
CMakeFiles\cmTC_ab5bc.dir\buildBuilding C object CMakeFiles/cmTC_ab5bc.dir/testCCompiler.c.obj
C:\PROGRA~2\MICROS~2\2017\COMMUN~1\VC\Tools\MSVC\1413~1.261\bin\Hostx86\x64\cl.exe @C:\Users\Greg\AppData\Local\Temp\nm2D12.tmp
testCCompiler.c
Linking C executable cmTC_ab5bc.exe
"C:\Program Files\CMake\bin\cmake.exe" -E vslinkexe --intdir=CMakeFiles\cmTCab5bc.dir --manifests -- C:\PROGRA~2\MICROS~2\2017\COMMUN~1\VC\Tools\MSVC\1413~1.261\bin\Hostx86\x64\link.exe /nologo @CMakeFiles\cmTCab5bc.dir\objects1.rsp @C:\Users\Greg\AppData\Local\Temp\nm2F65.tmp
Detecting C compiler ABI info compiled with the following output: Change Dir: C:/Program Files (x86)/gz-ws/gazebo/build/CMakeFiles/CMakeTmp
Run Build Command:"nmake" "/NOLOGO" "cmTC9d093\fast" "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.13.26128\bin\HostX86\x86\nmake.exe" -f CMakeFiles\cmTC9d093.dir\build.make /nologo -L
CMakeFiles\cmTC_9d093.dir\buildBuilding C object CMakeFiles/cmTC_9d093.dir/CMakeCCompilerABI.c.obj
C:\PROGRA~2\MICROS~2\2017\COMMUN~1\VC\Tools\MSVC\1413~1.261\bin\Hostx86\x64\cl.exe @C:\Users\Greg\AppData\Local\Temp\nm4D9B.tmp
CMakeCCompilerABI.c
Linking C executable cmTC_9d093.exe
"C:\Program Files\CMake\bin\cmake.exe" -E vslinkexe --intdir=CMakeFiles\cmTC9d093.dir --manifests -- C:\PROGRA~2\MICROS~2\2017\COMMUN~1\VC\Tools\MSVC\1413~1.261\bin\Hostx86\x64\link.exe /nologo @CMakeFiles\cmTC9d093.dir\objects1.rsp @C:\Users\Greg\AppData\Local\Temp\nm4FFD.tmp
Determining if the CXX compiler works passed with the following output: Change Dir: C:/Program Files (x86)/gz-ws/gazebo/build/CMakeFiles/CMakeTmp
Run Build Command:"nmake" "/NOLOGO" "cmTC30b7b\fast" "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.13.26128\bin\HostX86\x86\nmake.exe" -f CMakeFiles\cmTC30b7b.dir\build.make /nologo -L
CMakeFiles\cmTC_30b7b.dir\buildBuilding CXX object CMakeFiles/cmTC_30b7b.dir/testCXXCompiler.cxx.obj
C:\PROGRA~2\MICROS~2\2017\COMMUN~1\VC\Tools\MSVC\1413~1.261\bin\Hostx86\x64\cl.exe @C:\Users\Greg\AppData\Local\Temp\nm5ABA.tmp
testCXXCompiler.cxx
Linking CXX executable cmTC_30b7b.exe
"C:\Program Files\CMake\bin\cmake.exe" -E vslinkexe --intdir=CMakeFiles\cmTC30b7b.dir --manifests -- C:\PROGRA~2\MICROS~2\2017\COMMUN~1\VC\Tools\MSVC\1413~1.261\bin\Hostx86\x64\link.exe /nologo @CMakeFiles\cmTC30b7b.dir\objects1.rsp @C:\Users\Greg\AppData\Local\Temp\nm5D6A.tmp
Detecting CXX compiler ABI info compiled with the following output: Change Dir: C:/Program Files (x86)/gz-ws/gazebo/build/CMakeFiles/CMakeTmp
Run Build Command:"nmake" "/NOLOGO" "cmTCbc91c\fast" "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.13.26128\bin\HostX86\x86\nmake.exe" -f CMakeFiles\cmTCbc91c.dir\build.make /nologo -L
CMakeFiles\cmTC_bc91c.dir\buildBuilding CXX object CMakeFiles/cmTC_bc91c.dir/CMakeCXXCompilerABI.cpp.obj
C:\PROGRA~2\MICROS~2\2017\COMMUN~1\VC\Tools\MSVC\1413~1.261\bin\Hostx86\x64\cl.exe @C:\Users\Greg\AppData\Local\Temp\nm6D19.tmp
Linking CXX executable cmTC_bc91c.exe
"C:\Program Files\CMake\bin\cmake.exe" -E vslinkexe --intdir=CMakeFiles\cmTCbc91c.dir --manifests -- C:\PROGRA~2\MICROS~2\2017\COMMUN~1\VC\Tools\MSVC\1413~1.261\bin\Hostx86\x64\link.exe /nologo @CMakeFiles\cmTCbc91c.dir\objects1.rsp @C:\Users\Greg\AppData\Local\Temp\nm70E3.tmp
Detecting CXX [] compiler features compiled with the following output: Change Dir: C:/Program Files (x86)/gz-ws/gazebo/build/CMakeFiles/CMakeTmp
Run Build Command:"nmake" "/NOLOGO" "cmTCd3df0\fast" "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.13.26128\bin\HostX86\x86\nmake.exe" -f CMakeFiles\cmTCd3df0.dir\build.make /nologo -L
CMakeFiles\cmTC_d3df0.dir\buildBuilding CXX object CMakeFiles/cmTCd3df0.dir/featuretests.cxx.obj
C:\PROGRA~2\MICROS~2\2017\COMMUN~1\VC\Tools\MSVC\1413~1.261\bin\Hostx86\x64\cl.exe @C:\Users\Greg\AppData\Local\Temp\nm81CA.tmp
feature_tests.cxx
Linking CXX executable cmTC_d3df0.exe
"C:\Program Files\CMake\bin\cmake.exe" -E vslinkexe --intdir=CMakeFiles\cmTCd3df0.dir --manifests -- C:\PROGRA~2\MICROS~2\2017\COMMUN~1\VC\Tools\MSVC\1413~1.261\bin\Hostx86\x64\link.exe /nologo @CMakeFiles\cmTCd3df0.dir\objects1.rsp @C:\Users\Greg\AppData\Local\Temp\nm84D8.tmp
Feature record: CXX_FEATURE:1cxx_aggregate_default_initializers Feature record: CXX_FEATURE:1cxx_alias_templates Feature record: CXX_FEATURE:1cxx_alignas Feature record: CXX_FEATURE:1cxx_alignof Feature record: CXX_FEATURE:1cxx_attributes Feature record: CXX_FEATURE:1cxx_attribute_deprecated Feature record: CXX_FEATURE:1cxx_auto_type Feature record: CXX_FEATURE:1cxx_binary_literals Feature record: CXX_FEATURE:1cxx_constexpr Feature record: CXX_FEATURE:1cxx_contextual_conversions Feature record: CXX_FEATURE:1cxx_decltype Feature record: CXX_FEATURE:1cxx_decltype_auto Feature record: CXX_FEATURE:1cxx_default_function_template_args Feature record: CXX_FEATURE:1cxx_defaulted_functions Feature record: CXX_FEATURE:1cxx_defaulted_move_initializers Feature record: CXX_FEATURE:1cxx_delegating_constructors Feature record: CXX_FEATURE:1cxx_deleted_functions Feature record: CXX_FEATURE:1cxx_digit_separators Feature record: CXX_FEATURE:1cxx_enum_forward_declarations Feature record: CXX_FEATURE:1cxx_explicit_conversions Feature record: CXX_FEATURE:1cxx_extended_friend_declarations Feature record: CXX_FEATURE:1cxx_extern_templates Feature record: CXX_FEATURE:1cxx_final Feature record: CXX_FEATURE:1cxx_func_identifier Feature record: CXX_FEATURE:1cxx_generalized_initializers Feature record: CXX_FEATURE:1cxx_generic_lambdas Feature record: CXX_FEATURE:1cxx_inheriting_constructors Feature record: CXX_FEATURE:1cxx_inline_namespaces Feature record: CXX_FEATURE:1cxx_lambdas Feature record: CXX_FEATURE:1cxx_lambda_init_captures Feature record: CXX_FEATURE:1cxx_local_type_template_args Feature record: CXX_FEATURE:1cxx_long_long_type Feature record: CXX_FEATURE:1cxx_noexcept Feature record: CXX_FEATURE:1cxx_nonstatic_member_init Feature record: CXX_FEATURE:1cxx_nullptr Feature record: CXX_FEATURE:1cxx_override Feature record: CXX_FEATURE:1cxx_range_for Feature record: CXX_FEATURE:1cxx_raw_string_literals Feature record: CXX_FEATURE:1cxx_reference_qualified_functions Feature record: CXX_FEATURE:1cxx_return_type_deduction Feature record: CXX_FEATURE:1cxx_right_angle_brackets Feature record: CXX_FEATURE:1cxx_rvalue_references Feature record: CXX_FEATURE:1cxx_sizeof_member Feature record: CXX_FEATURE:1cxx_static_assert Feature record: CXX_FEATURE:1cxx_strong_enums Feature record: CXX_FEATURE:1cxx_template_template_parameters Feature record: CXX_FEATURE:1cxx_thread_local Feature record: CXX_FEATURE:1cxx_trailing_return_types Feature record: CXX_FEATURE:1cxx_unicode_literals Feature record: CXX_FEATURE:1cxx_uniform_initialization Feature record: CXX_FEATURE:1cxx_unrestricted_unions Feature record: CXX_FEATURE:1cxx_user_literals Feature record: CXX_FEATURE:1cxx_variable_templates Feature record: CXX_FEATURE:1cxx_variadic_macros Feature record: CXX_FEATURE:1cxx_variadic_templates**
Asked by gyronike on 2018-04-08 19:34:41 UTC
Out of curiosity, what instructions are you following to install Gazebo on Windows 10? I wasn't aware that it was possible to run Gazebo on Windows.
Asked by josephcoombe on 2018-04-10 08:49:45 UTC
