/cmd_VEL topic is missing edit
hi ,
i have installed (again) Indigo with its default Gazebo as well as Hectorquadrotor link text. I cant find the topic /cmdvel in order to send a flying command. also , i did install ardroneautonomy plus tumsimulator and the same situation . here is a list of the topics when launching roslaunch cvg_sim_gazebo ardrone_testworld.launch according to link text:
rostopic list
/aerodynamics/wrench
/altimeter
/altimeter/parameter_descriptions
/altimeter/parameter_updates
/clock
/command/motor
/command/wrench
/fix
/fix/position/parameter_descriptions
/fix/position/parameter_updates
/fix/status/parameter_descriptions
/fix/status/parameter_updates
/fix/velocity/parameter_descriptions
/fix/velocity/parameter_updates
/fix_velocity
/gazebo/link_states
/gazebo/model_states
/gazebo/parameter_descriptions
/gazebo/parameter_updates
/gazebo/setlinkstate
/gazebo/setmodelstate
/ground_truth/state
/joint_states
/magnetic
/magnetic/parameter_descriptions
/magnetic/parameter_updates
/motor_pwm
/motor_status
/pressure_height
/propulsion/wrench
/quadro/trigger
/raw_imu
/rawimu/accel/parameterdescriptions
/rawimu/accel/parameterupdates
/raw_imu/bias
/rawimu/rate/parameterdescriptions
/rawimu/rate/parameterupdates
/rawimu/yaw/parameterdescriptions
/rawimu/yaw/parameterupdates
/rosout
/rosout_agg
/sonar_height
/sonarheight/parameterdescriptions
/sonarheight/parameterupdates
/supply
/tf
/tf_static
/wind
had anyone seen such a thing before ? ps: i think in both cases i saw the same topics (hector and ardrone).
thanks in advance
Asked by Caesar84 on 2018-04-09 15:45:45 UTC
Did you enable the motors as it says in the tutorial: rosservice call /enable_motors "enable: true"
Asked by Raskkii on 2018-04-10 02:16:47 UTC
