Failed to load plugin /opt/ros/kinetic/lib/libgazebo_ros_api_plugin.so
I installed gazebo 7.11.1 from the source code.
In addition, I installed gazebo-ros-pkgs and gazebo-ros-control from the binary.
With the following command, Gazebo starts without error.
$ rosrun gazebo_ros gazebbo
However, when running the rrbot_gazebo launch file of a "Tutorial: Using a URDF in Gazebo", the RRBot did not spawn. (But I can spawn sdf model by Insert tab.)
$ roslaunch rrbot_gazebo rrbot_world.launch
I rewritten rrbotworld.launch to run emptyworld.launch with the --verbose option.
Then the following error was occurred.
[Err] [Plugin.hh:165] Failed to load plugin /opt/ros/kinetic/lib/libgazebo_ros_api_plugin.so: /opt/ros/kinetic/lib/libgazebo_ros_api_plugin.so: undefined symbol: _ZN6gazebo4msgs15WorldStatistics17default_instance_E
libgazeborosapiplugin.so exists in /opt/ros/kinetic/lib/.
So I thought that the path did not export and I set GAZEBOPLUGIN_PATH.
$ export GAZEBO_PLUGIN_PATH=/opt/ros/kinetc/lib:${GAZEBO_PLUGIN_PATH}
$ echo $GAZEBO_PLUGIN_PATH
However, the error did not change.
A question with a similar error already exists, but it seems that use custom plugins.
I did not find anything about errors with default plugins, as far as I was looking for.
I wonder how I can resolve this problem.
The environment is as follows.
Ubuntu: 16.04
ROS: Kinetic
Gazebo: 7.11.1
Asked by NT on 2018-04-23 08:06:23 UTC
I have meet such issue because I tried to install gazebo from source. The main season is that libgazebo_ros_api_plugin.so is trying to use gazebo::msgs::WorldStatistics which is not provided. That is, it does not link to all "libgazebo_msgs.so...." files. The thing you can do is delete gazebo7 completely and reinstall it with apt-get. Then it will solve the issue.
Asked by frank_hu on 2019-08-31 18:27:13 UTC
