How to attach my lidar to a robot at an angle in gazebo?
In gazebo, is there an easy way to attach my lidar model to an existing robot? What do I do if I need to attach the lidar at an angle? I followed this tutorial ( http://gazebosim.org/tutorials?tut=gu... ) to build my lidar model. I tried changing the pose of my revolute to be at an angle, but can't seem to be able to make the lidar turn say tilted at 30 degrees. Instead, when I change the pose, the axis is off-center. Alternatively, I tried to use the magnet in gazebo to snap my lidar to a robot. I have seen videos of people having their lidars at an angle, so there must be a way to do this. Can you recommend an approach to this?
Asked by siquike on 2018-04-25 14:34:14 UTC
You should keep you lidar model the same and keep it as a separate model.
What you do is you take your robot model and include the lidar model into it. You can also set its position on the robot.
Take a look at this example: http://gazebosim.org/tutorials?tut=add_laser
Asked by Raskkii on 2018-04-27 02:52:33 UTC
