Can't load any mesh into gazebo
Hi everyone,
i was working on a model in which visual and collision geometry are defined through a .stl file(mesh). Everything was all right since today. Gazebo doesn't load anymore its mesh file. I also noticed that all the models that i can download from bitbucket have the same problem, except that for the ones which are provived with a png texture. I thought it might be a GPU problem, so i reinstalled the video drivers but nothing changed. And of course the terminal doesn't say nothing about errors or issues. Don't really know what to do :/
Asked by Lo11o2 on 2018-04-29 16:57:49 UTC
What Gazebo version are you using? What operating system? Can you run Gazebo in verbose mode to see if any errors show up?
Asked by chapulina on 2018-04-29 20:25:47 UTC
I'm using Gazebo 9.0.0 on Ubuntu 16.04 LTS. I tried to open gazebo in verbose and it says:
[Err] [SystemPaths.cc:412] File or path does not exist[""] [Err] [Visual.cc:2824] No mesh specified
I checked the path and it was right(relative). So i just tried to use an absolute path and it worked!!! I don't know why it's stopped working, everything was ok with the relative path until yesterday. Thank you very much for your tip :)
Asked by Lo11o2 on 2018-04-30 06:14:03 UTC
Glad to hear you figured it out! Just curious, what was the path relative to? To the model.sdf file?
Asked by chapulina on 2018-04-30 14:35:00 UTC
I had this in collision and visual tags:
file://meshes/chassis.stl
In the model directory i have: model.sdf, model.config and the directory meshes. It just stopped working, i don't know why. Never touched that part since the first time i loaded the model on Gazebo.
Asked by Lo11o2 on 2018-04-30 15:20:56 UTC
