How can i change a Gazebo model properties in runtime?
Hello I want to change the mass property of a link in runtime. When i use the SetMass() function, Gazebo detect the change of mass value in the properties menu (the left one) but in the simulation the link continues behaving as if nothing had happened.
Should I use other function to update the values? Thank you.
namespace gazebo
class joint_c : public ModelPlugin
this->model = _parent;
this->world= this->model->GetWorld();
this->mbox=this->world->GetModel("minibox");
this->jointR1_ = this->model->GetJoint("r1");
this->link1 = this->mbox->GetLink("link");
link1->GetInertial()->SetMass(800000); // Changing the mass
this->updateConnection = event::Events::ConnectWorldUpdateBegin(boost::bind(&joint_c::OnUpdate, this, _1));
public: void OnUpdate(const common::UpdateInfo &_info)
private:
physics::ModelPtr model;
physics::ModelPtr mbox;
physics::WorldPtr world;
event::ConnectionPtr updateConnection;
physics::JointPtr jointR1_;
physics::LinkPtr link1;
GZ_REGISTER_MODEL_PLUGIN(joint_c)
(re): I have tried to use the "virtual void UpdateParameters (sdf::ElementPtr _sdf)" function, but the console show me an error:
Error [Element.hh:360] Unable to find value for key[pose]
Error [Element.cc:684] Missing element description for [gravity]
My new lines of code are:
sdf::ElementPtr sdflink;
this->sdflink=this->link1->GetSDF();
this->sdflink->GetAttribute("name")->Set ("newName");
this->sdflink->GetElement("gravity")->Set(true);
this->sdflink->GetElement("pose")->Set(math::Pose(math::Vector3(-3, 0, 0), math::Quaternion(0, 0, 0)));
this->link1->UpdateParameters(sdflink);
What is going on?
Asked by lumaro on 2018-05-02 07:43:20 UTC
Hey there, i found a solution, just update the mass with UpdateMass();
function.
Asked by lumaro on 2018-05-04 04:11:24 UTC
Hi, I am also trying to do similar work. I have my robot carrying a payload. I want to change the payload mass at runtime. I found a way to do it, with rosservice call gazebo set link properties, "Gazebo detect the change of mass value in the properties menu (the left one) but in the simulation, the link continues behaving as if nothing had happened" if I understand your work correctly, you wrote a Model plugin and doing similar operation would you please specify where you added UpdateMass();?
Asked by r3hman on 2018-12-13 07:03:54 UTC
