Do any HDR camera sensor plugins exist?
I'm currently building a simulation which needs to reproduce camera images in challenging lighting environments. This will require rending a camera frame using HDR techniques and allowing control over the exposure settings. In a nut shell this plugin will need to render to a frame buffer that contains floating point values representing light intensity in lumens instead of 8 bit color values.
I have played around with the OGRE HDR examples looking to build a plugin to be able to do this, but I wanted to find if anyone else had aleady done this. I don't want to re-invent the wheel here!
Thanks.
Asked by PeteBlackerThe3rd on 2018-05-08 06:44:07 UTC
Hi, just wanted to know if you had any update on this!
Asked by robot_commander on 2022-07-25 19:42:23 UTC
