Simulated camra -> do I need to rectify its image?
Hey there,
I wonder if I need to rectify an image of a simulated camera (actually I need the images to be rectified)
I currently use this code to simulate a realsense camer a R200: 1 $(arg camerafps)</updaterate> <!-- should be 30 --> ${70.0 * pi/180.0} B8G8R8 $(arg camerawidth) $(arg cameraheight) 0.001 100
      <!-- disortion tag does not work in indigo -> go for kinetic! TODO
      <distortion>
        <k1>0.0</k1>
        <k2>0.0</k2>
        <k3>0.0</k3>
        <p1>-0.0</p1>
        <p2>-0.00</p2>
        <center>0.5 0.5</center>
      </distortion> -->
    <plugin name="${name}_camera_depth_controller" filename="libgazebo_ros_camera.so">
      <robotNamespace>$(arg robot_name)/sensor/${name}/rgb</robotNamespace>
      <imageTopicName>image_raw</imageTopicName>
      <cameraInfoTopicName>camera_info</cameraInfoTopicName>
      <frameName>${name}_rgb_optical_frame</frameName>
However I just get these topics:
/my_camera/sensor/camera/rgb/camera_info
/my_camera/sensor/camera/rgb/image_raw
/my_camera/sensor/camera/rgb/image_raw/compressed
/my_camera/sensor/camera/rgb/image_raw/compressed/parameter_descriptions
/my_camera/sensor/camera/rgb/image_raw/compressed/parameter_updates
/my_camera/sensor/camera/rgb/image_raw/compressedDepth
/my_camera/sensor/camera/rgb/image_raw/compressedDepth/parameter_descriptions
/my_camera/sensor/camera/rgb/image_raw/compressedDepth/parameter_updates
/my_camera/sensor/camera/rgb/image_raw/theora
/my_camera/sensor/camera/rgb/image_raw/theora/parameter_descriptions
/my_camera/sensor/camera/rgb/image_raw/theora/parameter_updates
So no rectified image....
How can I also simulate a camera and get its rectified image?
Asked by markus on 2018-05-17 08:12:43 UTC
Excuse my ignorance, but out of curiosity, what do you mean by a rectified image?
Asked by josephcoombe on 2018-05-17 08:49:42 UTC
It is one that compensates for lens distortion based off of the calibration file correct?
Asked by cmfuhrman on 2018-05-18 10:14:14 UTC
Yes correct check here: http://wiki.ros.org/image_proc
Asked by markus on 2018-05-24 14:17:56 UTC
