I have this error while opening the Gazebo from terminal : Unable to find shader lib. Shader generating will fail. What should I do so that gazebo is back on track ? Read more in description
I had install Gazebo 9 on my Ubuntu 16.04. For some reason, I had to remove it and then install it once again. After installing, I notable to open the gazebo from terminal. It shows above error. I checked directory of gazebo-9. It had only setup.sh file. No other file was there. But, when I installed it first time, it had many files. Need help to resolve this.
Asked by pk on 2018-05-17 15:01:32 UTC
