How do I get the IMU to use the NED reference frame?
I'm not quite sure if the imu orientation_reference_frame
is the correct thing to set, but I've set my IMU to use the following options. When testing, I've noticed that the IMU is not outputting in a NED reference frame. A counter clockwise rotation about Z is positive when it should be negative in the NED frame. Also, the accelerometer is reading +9.8 at rest when it should be -9.8 in a NED reference frame.
<sensor type="imu" name="imu_sensor">
<always_on>true</always_on>
<update_rate>100.0</update_rate>
<imu>
<orientation_reference_frame>
<localization>NED </localization>
</orientation_reference_frame>
</imu>
I've also set these world settings:
<spherical_coordinates>
<surface_model>EARTH_WGS84</surface_model>
<world_frame_orientation>NED</world_frame_orientation>
<latitude_deg>42.2546</latitude_deg>
<longitude_deg>-83.7648</longitude_deg>
<elevation>281</elevation>
<heading_deg>0</heading_deg>
</spherical_coordinates>
Asked by MartinDeegan on 2018-05-17 22:14:24 UTC
