link position not in correct position
<link name="body">
<visual>
<mesh filename="package://urdf_tutorial/meshes/body.dae"/>
<material
name="">
<color
rgba="0 1 0 1" />
<collision>
<mass value="0.0001"/>
<inertia ixx="0.03410357" ixy="0.00003043" ixz="0.000043960" iyy="0.003279236" iyz="0.0" izz="0.000259210"/>
<link name="blade">
<visual>
<origin rpy="0 0 0" xyz="0 0 10"/>
<mesh filename="package://urdf_tutorial/meshes/blade.dae"/>
<material name="blue">
<color rgba="0 0 0.8 1"/>
<collision>
<inertia ixx="0.000251114" ixy="0.000002954" ixz="0.000185428" iyy="0.003055804" iyz="0.0" izz="0.002817239"/>
<joint name="joint1" type="continuous">
<parent link="body"/>
<child link="blade"/>
<axis xyz="0 0 1"/>
<origin xyz="0.105987 3.12205 12.4372"/>
</robot>
above is the urdf of model. here no matter how much i change the position of the link blade, it's position don't changes from one position.
above is the urdf of model. here no matter how much i change the position of the link blade, it's position don't changes from one position. image description
what should i do? i have placed its position in blender correctly. i'm using gazebo 9. when i place its position as 0 0 0 its position comes correctely but the joint position is at 0 0 0. so the problem is when ever i change the position of the joint the position of the blade link also chagnes. in rviz the model with joint position 0 0 0:
Asked by hari1234 on 2018-05-23 11:25:46 UTC
I think you need to change the position inside the visual tag. Try changing the xyz = "0 0 10" to xyz="0 0 0". The visual pose is with reference to the origin of the link.
<link name="blade">
<visual>
<origin rpy="0 0 0" xyz="0 0 0"/>
Asked by skej on 2018-05-24 13:16:00 UTC
