Is it possible to decrease the ground_plane size ?
I see that the ground_plane model is used in the empty world. and it seems to infinitely large. My bot travels to the edge of the defined size of 100x100 , but it still seems to keep on going and floating in air. Is it possible to make it fall down?
Any input would be useful. Thanks
Asked by gkbot on 2018-05-28 09:07:09 UTC
The plane is infinite for physics, so if you want the robot to fall off, your best bet is to create a large box as @raequin suggested, be sure to make it static.
Asked by chapulina on 2018-05-29 10:22:25 UTC
What if you put a 100x100 cuboid on top of ground_plane? Then the robot would fall off.
Asked by raequin on 2018-05-29 09:59:26 UTC
