Modfy a joints friction value deuring exacution
The platform I have has an un-actuated joint that can lock or unlock and be passively actuated by other joints. I was hoping to simulate the locking and unlocking modifying the joints friction value, very large for locked and small for unlocked. Is there a way to modify the friction value during simulation?
I have looked through rosservice and rospram with no luck is this possible from gazebo? or is there a better way of solving this problem?
<!-- this line -->
Asked by tonka46 on 2018-06-08 01:04:29 UTC
Gazebo does support this functionality for ODE revolute, prismatic, and universal joints refer pull request https://bitbucket.org/osrf/gazebo/pull-requests/1221/implement-coulomb-joint-friction-for-ode/diff for details. This also highlights the interaction between fmax and friction and not to set them at the same time.
To avoid the conflict of setting fmax and friction while maintaining existing functionality I copied SetJointProperties.srv and ODEJointProperties.msg making SetJointFriction.srv and ODEJointFriction.msg
string joint_name                               # name of joint
gazebo_msgs/ODEJointFriction ode_joint_config # access to ODE joint dynamics properties
bool success                                    # return true if get successful
string status_message                           # comments if available
# access to low level joint properties, change these at your own risk
float64[] friction            # joint friction
gazebo_ros_api_plugin.cpp was modified by copying setJointProperties() to create
bool GazeboRosApiPlugin::setJointFriction(gazebo_msgs::SetJointFriction::Request &req,
                                        gazebo_msgs::SetJointFriction::Response &res)
  /// @todo: current settings only allows for setting of 1DOF joints (e.g. HingeJoint and SliderJoint) correctly.
  gazebo::physics::JointPtr joint;
#if GAZEBO_MAJOR_VERSION >= 8
  for (unsigned int i = 0; i < world_->ModelCount(); i ++)
    joint = world_->ModelByIndex(i)->GetJoint(req.joint_name);
#else
  for (unsigned int i = 0; i < world_->GetModelCount(); i ++)
    joint = world_->GetModel(i)->GetJoint(req.joint_name);
#endif
    if (joint) break;
  if (!joint)
    res.success = false;
    res.status_message = "SetJointFriction: joint not found";
    return true;
  else
    for(unsigned int i=0;i< req.ode_joint_config.friction.size();i++)
      joint->SetParam("friction",i,req.ode_joint_config.friction[i]);
    res.success = true;
    res.status_message = "SetJointFriction: properties set";
    return true;
finally, duplicate the service advertisers
Asked by tonka46 on 2018-06-18 19:16:57 UTC
Archived version of the Bitbucket PR referenced in this answer can be found at:
https://osrf-migration.github.io/gazebo-gh-pages/#!/osrf/gazebo/pull-requests/1221/page/1
Asked by danzimmerman on 2023-03-22 19:18:52 UTC
