DRC Simulator can't run again, after installing Gazebo!
asked 2012-11-11 12:13:28 -0500
Tung Go gravatar image
updated 2012-11-12 01:38:21 -0500
Last week, DRC Sim still ran pretty smoothly after i installed it in the pre - compiled binaries selection .
But then when i tried to install a stand-alone version of Gazebo, as suggested in the official DRC Kickoff Tutorials, to get familiar with it, it became a disaster!
Now, DRC Sim can't even run again, with a warning window poping up (sorry, i can't attach the screenshot here. It's required that i have at least 60 karma to do so) . Frustrated, I've browsed through all ROS and Gazebo Q&As without any answer. Here's how the terminal diagnosed the problem:
process[tf2_buffer_server-6]: started with pid [4002]
[ WARN] [1352705611.085392264]: You've passed in true for auto_start for the C++ action server at [/tf2_buffer_server]. You should always pass in false to avoid race conditions.
Warning [parser.cc:375] Gazebo SDF has no <gazebo> element in file[/usr/share/drcsim-1.0/models/drc_robot/model.sdf]
Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading' from '/usr/lib/python2.7/threading.pyc'> ignored
process[drc_robot_controllers_spawner-7]: started with pid [4031]
Warning [parser_urdf.cc:1125] urdf2gazebo: link[left_camera_optical_frame] has no inertia, parent joint [left_camera_optical_frame_joint] ignored
.Warning [parser_urdf.cc:1129] urdf2gazebo: link[left_camera_optical_frame] has no inertia, not modeled in gazebo
Warning [parser_urdf.cc:1125] urdf2gazebo: link[right_camera_optical_frame] has no inertia, parent joint [right_camera_optical_frame_joint] ignored
.Warning [parser_urdf.cc:1129] urdf2gazebo: link[right_camera_optical_frame] has no inertia, not modeled in gazebo
process[camhand_controllers_spawner-8]: started with pid [4032]
Warning [parser.cc:286] parse from urdf file [/usr/share/drcsim-1.0/models/drc_robot/model.sdf].
X Error of failed request:  BadRequest (invalid request code or no such operation)
  Major opcode of failed request:  154 (GLX)
  Minor opcode of failed request:  19 (X_GLXQueryServerString)
  Serial number of failed request:  12
  Current serial number in output stream:  12
Error [Transport.cc:102] Unable to get topic namespaces in [50] tries.
Error [Node.cc:72] No namespace found
Warning [gazebo_main.cc:57] escalating to SIGKILL on server
[gazebo-2] process has finished cleanly
log file: /home/airobot/.ros/log/412ca1fe-2c9b-11e2-81f2-4c80930ee359/gazebo-2*.log
Any help or suggestion, please?
Can you post the results of glxinfo |grep direct ?
SL Remy gravatar imageSL Remy ( 2012-11-14 10:18:27 -0500 )edit
answered 2012-11-12 12:12:36 -0500
hsu gravatar image
The error:
looks suspiciously like an issue with the GPU driver. Did the linux kernel get updated and the system requires a reboot?
What does glxinfo say?
name of display: :0.0 X Error of failed request: BadRequest (invalid request code or no such operation) Major opcode of failed request: 154 (GLX) Minor opcode of failed request: 19 (X_GLXQueryServerString) Serial number of failed request: 12 Current serial number in output stream:12
Tung Go gravatar imageTung Go ( 2012-11-12 23:18:03 -0500 )edit
one possibility is the kernel got updated while you were updating gazebo/drcsim, so the gpu driver is in limbo. If that's the case, just reboot your computer to rectify this situation.
hsu gravatar imagehsu ( 2012-11-12 23:48:40 -0500 )edit
@hsu: As you and a friend of mine suggested, i did reboot it. But nothing improved! Still the problem occurs now. Another friend of mine also diagnosed and recommended the GPU need an update. Mine is an AMD Radeon. Any further suggesion? Thanks @hsu.
Tung Go gravatar imageTung Go ( 2012-11-13 04:22:33 -0500 )edit
There are a variety of things that you might need to do to get your GPU working properly. But none of that is Gazebo-specific and so is out of scope for this forum. You need to get glxinfo succeeding and returning direct rendering: Yes in its output before it makes sense to talk about Gazebo.
gerkey gravatar imagegerkey ( 2012-11-13 09:37:26 -0500 )edit
answered 2012-11-11 21:27:13 -0500
hugomatic gravatar image
Try installing drcsim. The stand-alone Gazebo installation instructions are for users of Gazebo that do not want to install the DRC simulation.
sudo apt-get install drcsim
Thanks @hugomatic. Actually, DRC was installed and run successfully before the trouble at hand. Still the error persists. Please, check out the updated results of launching the DRC simulator in my edited post above. Thanks again.
Tung Go gravatar imageTung Go ( 2012-11-12 01:40:14 -0500 )edit
Asked: 2012-11-11 12:13:28 -0500
Seen: 453 times
Last updated: Nov 12 '12
