publish to gazebo topic from c++ node in ROS
Hello everyone, i'm trying command my robot in gazebo by using a C++ node in ROS, but i didn't find how to get the connexion between my urdf robot in gazebo and my C++ node.
i can make the joint of my robot move by using rqt_gui, by i don't know how to publish some random positions using C++ node in ROS
Please help.
Asked by samo on 2018-06-25 10:05:27 UTC
- add head file
#include <gazebo/transport/TransportTypes.hh>
add definition of node and Publisher
transport::NodePtr node;
transport::PublisherPtr pub_mydata;
Init node
transport::NodePtr node(new transport::Node()); node->Init("test"); this->pub_mydata = node->Advertise<msgs::Vector3d>("~/MyData");
Publish data
msgs::Vector3d msg_Vector3d; msgs::Set(&msg_Vector3d, this->data_from_link); this->pub_mydata->Publish(msg_Vector3d);
Visualize data in gazebo9
ctrl+p
If you don't want to control your robot by pulgin but using ros-control . Then you need to Subscribe your cmd ,and then publish the value to ros-controller you used.
If you want to control your robot by a plugin, for example , model plugin.
You should bind a
ros::Subscribe
to receive your message.ros::SubscribeOptions PositionCommandSo = ros::SubscribeOptions::create<your_msgs::PositionCommand>("~/PositionCommand", 1, boost::bind(&YourPlugin::SetPositionCommand, this, _1),ros::VoidPtr(), &this->rosQueue);
void YourPlugin::SetPositionCommand(const your_msgs::PositionCommand::ConstPtr &_msg)
// TODO
std::cout<<"recive PositionCommand massage"<<std::endl;
//Update your cmd value tor control
this->PID_refer_x = _msg->action[0];
- Update your cmd value to a controller, for example PID.
Asked by longwoo on 2018-06-26 01:20:14 UTC
hello, my publisher is like that :
ros::Publisher pub=n.advertise
i'm trying to publish on gazebo topic so my robot can move
Asked by samo on 2018-06-26 02:48:31 UTC
i can command my robot like i said before by using rqt_gui, right there i'm choosing /My_pkg/joint1_position_controller/command with a sin(i/100)*0.5 command, and my robot move
My question is how to do the same but by using this publisher to communicate with gazebo
Asked by samo on 2018-06-26 02:52:42 UTC
If you want to control your robot. Then you need a plugin, for example , model plugin.
1. You should bind a ros::Subscribe
2. Update your cmd value to a controller, for example PID.
Asked by longwoo on 2018-06-26 06:22:45 UTC
thank you for your answer. I have another question if you didn't mind, can i be able to publish to each link to control its joint angles? without using plugins
Asked by samo on 2018-06-26 08:09:56 UTC
yes, you can do it by using actionlib. Here is the python tutorial
.http://wiki.ros.org/dynamixel_controllers/Tutorials/Creatingdynamixelactionclient .
C++ is similar.
Asked by longwoo on 2018-06-26 21:22:33 UTC
