UR3 URDF modification does not load well in Gazebo
Hi all! I'm quite new to Gazebo and i'm working with an UR3. I'm trying to add an end effector that I created. I managed to make the model with the URDF file, but when I try to load it in Gazebo I get the following error:
[ERROR] [1530088013.617060575, 0.630000000]: Could not find joint 'shoulder_pan_joint' in 'hardware_interface::PositionJointInterface'.
[ERROR] [1530088013.617378163, 0.630000000]: Failed to initialize the controller
[ERROR] [1530088013.617556843, 0.630000000]: Initializing controller 'arm_controller' failed
Error when loading arm_controller
[ERROR] [1530088013.621726505, 0.631000000]: Could not start controller with name arm_controller because no controller with this name exists
Error when starting ['arm_controller']
And i don't understand why that happens, since the shoulderpanjoint exists and works in the original file that I modified in order to add the end effector. The model loads, but it falls down, here's a picture of it:
If anyone happens to know what's the problem and how to solve it, it would help me a lot. I'm using Ros Kinetic and Ubuntu 16.04. Thank you very much in advance!
Asked by thisyearspairo on 2018-06-27 03:36:19 UTC
What launch file are you running to load the urdf? Looks like the urdf is spawning just fine, but
ros_control
is generating ERRORS. I'd also double check to make sure that you made only additive changes - mistakes happen.Asked by josephcoombe on 2018-06-27 12:30:10 UTC
Hello! Yes, it was a error of deleting something that i shouldn't have, I managed to make it work, but thank you very much for your answer.
Asked by thisyearspairo on 2018-06-28 02:43:13 UTC
Hi I met with the same problem, could you please tell me how to fix it? Much appreciated.
Asked by saltedfish_mountain on 2019-03-17 07:58:38 UTC
Problem fixed. This problem appears because of lacking transmission tab. My robot.xacro file does not contain transmission for the robot. I send the xacro to the parameter server and spawn the robot in gazebo, so this problem appears.
Asked by saltedfish_mountain on 2019-03-17 08:36:47 UTC
Actually I have a robot.urdf file which contains transmission for the robot. So I use the following command in the robot.launch file:
< param name="robot_description" textfile="$(find kuka_kr210_support)/urdf/kr210l150.urdf"/ >
This line send the urdf to the parameter server. It works well. Hope this help others who are struggling with the same problem.
Asked by saltedfish_mountain on 2019-03-17 08:38:24 UTC
