How to read information from the Openni depth camera in Gazebo
Hello
I am using the Openni depth camera plugin in Gazebo. However; I faced some issues:
When I tried to see what's being published to the camera/depth/image_raw, I didn't know: - how to read the distance detected by the depth camera? - how to extract the images captured by the camera so I can use them for my robot learning?
Moreover; I opened RViz to see the image, it says that there is no image.
Can someone help me solve these issues?
Thanks a lot for your help.
Asked by user90 on 2018-06-29 03:47:21 UTC
The depth image is encoded as "32FC1", meaning that each pixel is a one channel 32 bit floating point number representing the distance from the camera.
This depends on what you want to do with the images. They are published as a ROS topic, so you can write a Subscriber to capture them into another program.
Perhaps you are subscribed to the wrong topic, use rostopic list
to see what topics are available.
Asked by kev-the-dev on 2018-06-29 18:12:57 UTC
I understand your point of view concerning the distance between each pixel and the camera, however I am obtaining illogical numbers that represents the distance
Asked by user90 on 2018-07-09 09:41:58 UTC
The image is sent as ros image format. To get the real distance you can convert it to openCV first. http://wiki.ros.org/cv_bridge/Tutorials/ConvertingBetweenROSImagesAndOpenCVImagesPython
Asked by Zeckurbo on 2021-01-21 07:44:47 UTC
