How to run citysim in gazebo
https://bitbucket.org/osrf/citysim
The homepage says:
Running
Source setup file
. [install_prefix]/share/citysim/setup.sh
Open world
gazebo worlds/simple_city.world
I already done building and updating world file. But, i can't running because i'm a beginner. i don't know how to run citysim exactly. Can you write exact command for Source setup file and Open world?? i'm using ROS-Kinetic(Ubuntu 16.04 LTS)
Asked by jeonguu.kim on 2018-08-21 04:57:03 UTC
What Gazebo version are you using? Also note that CitySim by itself doesn't need ROS.
Asked by chapulina on 2018-08-21 10:05:07 UTC
Hi chapulina, i'm using gazebo9 version. Thank you about note. Then how can i running citysim without ROS??
Asked by jeonguu.kim on 2018-08-27 00:18:45 UTC
The commands you wrote look correct. What's the problem you're having?
Asked by chapulina on 2018-08-27 10:28:56 UTC
I also facing the same issues. I run above commands. The gazebo couldn't show up with the simple_city.world. However, when i try with the rendering.world, it works fine, the gazebo showed up the rendering.world.
Asked by HappySamuel on 2019-03-05 20:51:23 UTC
