How to edit/submit fixes to tutorials?
I am going through Gazebo tutorials and occasionally I encounter minor errors in the text, for example here:
http://gazebosim.org/tutorials?tut=hydrodynamics&cat=plugins
"Drag out the left hand menu and select the yellow submarine model"
It really should say "right hand menu".
The blades are tilted such that the angle of attack for the blades is always less 45 degrees
This should say "less than 45 degrees"...
I have also encountered broken links, code samples for older versions of Gazebo, a number of things like that. Is there a way for me to submit these errors somewhere so that they are fixed eventually? I didn't find any sources for tutorials in the Gazebo repository at bitbucket...
Asked by maksymczech on 2018-08-23 05:34:52 UTC
There's a tutorial on how to edit tutorials ;) Thanks in advance for the contributions!
http://gazebosim.org/tutorials?tut=tutorial_contrib&cat=development#Modifyatutorial
Asked by chapulina on 2018-08-23 10:44:05 UTC
Lol :D Thank you
Asked by maksymczech on 2018-08-23 17:52:31 UTC
