the state of the robot is not synchronized in gazebo and rviz
Gazebo.launch:
<launch>
  <arg name="use_sim_time" default="true"/>
  <arg name="headless" default="false"/>
  <arg name="debug" default="false"/>
    <arg name="debug" value="$(arg debug)"/>
    <arg name="gui" value="$(arg gui)"/>
    <arg name="paused" value="$(arg paused)"/>
    <arg name="use_sim_time" value="$(arg use_sim_time)"/>
    <arg name="headless" value="$(arg headless)"/>
  <param name="robot_description" command="$(find xacro)/xacro --inorder '$(find vehicle_mover)/urdf/vehicle_mover.urdf.xacro'" />
  <node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen" args="-urdf -model vehicle_mover -param robot_description"></node>
</launch>
Rviz.launch:
<launch>
  <arg name="model" default="$(find vehicle_mover)/urdf/vehicle_mover.urdf.xacro"/>
  <arg name="gui" default="true" />
  <arg name="rvizconfig" default="$(find vehicle_mover)/rviz/urdf.rviz" />
  <param name="robot_description" command="$(find xacro)/xacro --inorder $(arg model)" />
  <param name="use_gui" value="$(arg gui)"/>
  <node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher" />
  <node name="robot_state_publisher" pkg="robot_state_publisher" type="state_publisher" />
  <node name="rviz" pkg="rviz" type="rviz" args="-d $(arg rvizconfig)" required="true" />
</launch>
These are the nodes and topics that are generated after the above files are launched: image description
The current situation is that if I control the robot to move in gazebo, the robot observed in rviz is still in place. Obviously this is because /gazebo node is not publishing messages to the /robot_state_publisher node. So how to let gazebo publish messages?
Asked by duhyu1 on 2018-10-07 08:55:03 UTC
