Has anybody gotten the contact sensor example to work in a repo-installed Gazebo 1.5.0
asked 2013-03-26 17:00:36 -0600
Ben B gravatar image
updated 2013-03-29 13:31:04 -0600
As mentioned in my other question, the Gazebo tutorial for 1.5.0 on the contact sensor isn't working for me. I've now tried it on two separate computers -- one of which has a brand new install of Gazebo 1.5. I've gone up to (and including) the step with gztopic echo /gazebo/default/box/link/my_contact. Nothing shows up. Not when I move the box around, not when I drag other cubes into it. Nothin'.
I was also having problems with the ray sensor. Andrei said it worked fine on his copy which is installed from source. I'm wondering if this is related.
Has anyone gotten this to work on a repo-installed version of Gazebo 1.5.0?
My output for the gztopic list command (while running contact.world):
$ gztopic list
/gazebo/default/pose/info
/gazebo/default/gui
/gazebo/default/log/status
/gazebo/default/response
/gazebo/default/world_stats
/gazebo/default/selection
/gazebo/default/model/info
/gazebo/default/light
/gazebo/default/physics/contacts
/gazebo/default/visual
/gazebo/default/request
/gazebo/default/joint
/gazebo/default/sensor
/gazebo/world/modify
/gazebo/default/diagnostics
/gazebo/default/factory
/gazebo/default/model/modify
/gazebo/default/scene
/gazebo/default/world_control
/gazebo/server/control
and for echoing the topic:
$ gztopic echo /gazebo/default/box/link/my_contact
Msg Waiting for master
Msg Publicized address: 142.103.111.179
Also, I should mention that echoing the /gazebo/default/diagnostics gives what, I think, is expected:
$ gztopic echo /gazebo/default/diagnostics
real_time {
  sec: 545
  nsec: 278030788
sim_time {
  sec: 543
  nsec: 639000000
real_time_factor: 0.99699413700000006
real_time {
  sec: 545
  nsec: 279033152
sim_time {
  sec: 543
  nsec: 640000000
real_time_factor: 0.99699413900000011
Echoing /gazebo/default/physics/contacts gives:
$ gztopic echo /gazebo/default/physics/contacts
contact {
  collision1: "box::link::box_collision"
  collision2: "ground_plane::link::collision"
  position {
    x: -0.500000000000538
    y: 0.5000000000027871
    z: -1.3116396857526524e-11
  position {
    x: 0.499999999999462
    y: 0.50000000000861855
    z: -1.3116396854834858e-11
  normal {
    x: 0
    y: 0
    z: 1
  normal {
    x: 0
    y: 0
    z: 1
  depth: 1.3116396857526524e-11
  depth: 1.3116396854834858e-11
  wrench {
    body_1_name: "box::link::box_collision"
    body_2_name: "ground_plane::link::collision"
    body_1_force {
      x: -2.3140274425398203e-05
      y: -0.58800230164949263
      z: 2.9400153497970845
    body_2_force {
      x: 0
      y: 0
      z: 0
    body_1_torque {
      x: 1.1760044495821824
      y: 1.4700192450579339
      z: 0.29401272095006686
    body_2_torque {
      x: 0
      y: 0
      z: 0
  wrench {
    body_1_force {
      x: 2.3140281286035522e-05
      y: -0.58800230164948963
      z: 2.940015349797072
    body_2_force {
      x: 0
      y: 0
      z: 0
    body_1_torque {
      x: 1.176004449599322
      y: -1.4700192450442133
      z: -0.29401272095006692
    body_2_torque {
      x: 0
      y: 0
      z: 0
  time {
    sec: 9
    nsec: 22000000
time {
  sec: 9
  nsec: 22000000
Welp. Installing from source didn't fix it either.
Ben B gravatar imageBen B ( 2013-03-26 18:33:24 -0600 )edit
We had two people at OSRF test each tutorial with the new debs before releasing, so yes we have gotten it to work. Can you paste the full output of what you see when you run gztopic list?
scpeters gravatar imagescpeters ( 2013-03-27 00:01:39 -0600 )edit
Updated with the outputs for listing the topics as well as echoing the sensor topic. Thanks for your attention, sc.
Ben B gravatar imageBen B ( 2013-03-27 16:25:37 -0600 )edit
can you turn on contact visualization and also make the models transparent (via the View menu) first, then place a sphere on top of the box contact sensor to see if a single contact point visualization appear?
iche033 gravatar imageiche033 ( 2013-03-28 04:08:54 -0600 )edit
Iche, I see one contact point between the box and the sphere. Also one contact point at every corner of the box that touches the ground.
Ben B gravatar imageBen B ( 2013-03-28 12:23:29 -0600 )edit
Also, something that may be noteworthy: When I visualize collisions and I move the box from its original position, an orange square remains on the ground where the box was.
Ben B gravatar imageBen B ( 2013-03-28 12:24:49 -0600 )edit
When I go to Window -> Topic Visualization and select /gazebo/default/box/link/my_contact, the reported frequency is 0.00 Hz and the bandwidth is 0.00 B/s. What do you guys see here?
Ben B gravatar imageBen B ( 2013-03-28 12:28:49 -0600 )edit
The orange square on the ground represents the collision shape of the ground plane. Can you also View Contacts and View Transparent?
scpeters gravatar imagescpeters ( 2013-03-28 12:49:21 -0600 )edit
scpeters, that's what "Iche, I see one contact point between the box and the sphere. Also one contact point at every corner of the box that touches the ground." was in regards to.
Ben B gravatar imageBen B ( 2013-03-28 15:45:00 -0600 )edit
do you see anything if you echo /gazebo/default/physics/contacts ?
iche033 gravatar imageiche033 ( 2013-03-29 03:42:46 -0600 )edit
answered 2013-04-09 14:03:05 -0600
Solution: One needs to add
<update_rate>5</update_rate>
Between the </contact> and </sensor> tags in order to get output on the terminal. The rate "5" can be changed to a different frequency if desired. I've added this to the tutorial page on the wiki here.
Asked: 2013-03-26 17:00:36 -0600
Seen: 536 times
Last updated: Apr 09 '13
