Gazebo crashes when trying to launch using static map plugin
Hi everyone,
I am fairly new to Gazebo so I am having a hard time figuring this out myself: I was trying to follow the tutorial on the static map plugin (http://gazebosim.org/tutorials?tut=static_map_plugin&cat=build_world) to use satellite imagery from Google Maps in my simulation. I have two machines running a freshly installed Ubuntu 18.04 LTS and Gazebo 3, one at work and one at home. On the machine at work the tutorial worked like a charm. Now I was trying to get the same results on my personal machine, but it won't work. I think there probably is a simple fix to this but I am not sure where to start. I checked the /tmp folder and it looks like all the downloaded files are there so not sure why I am getting this error. See the full output below. Would be great if anyone has a quick fix for this. Thank you!
 $ gazebo --verbose Dropbox/Masterthesis/Simulation/Gazebo-files/Worlds/static_map_plugin2.world
Gazebo multi-robot simulator, version 9.4.1
[Msg] Waiting for master.
[Msg] Publicized address: 10.0.0.88
[Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
[Msg] Downloading map tile: tile_37.386832_-122.065684.png
[Msg] Downloading map tile: tile_37.386832_-122.065255.png
[Msg] Downloading map tile: tile_37.386832_-122.064826.png
[Msg] Downloading map tile: tile_37.386491_-122.065684.png
[Msg] Downloading map tile: tile_37.386491_-122.065255.png
[Msg] Downloading map tile: tile_37.386491_-122.064826.png
[Msg] Downloading map tile: tile_37.38615_-122.065684.png
[Msg] Downloading map tile: tile_37.38615_-122.065255.png
[Msg] Downloading map tile: tile_37.38615_-122.064826.png
terminate called after throwing an instance of 'boost::filesystem::filesystem_error'
  what():  boost::filesystem::rename: No such file or directory: "/tmp/map_satellite_37.386491_-122.065255_100_100", "/home/js/.gazebo/models/map_satellite_37.386491_-122.065255_100_100"
Asked by JROS on 2018-11-07 12:44:09 UTC
Looks like I fixed it: I created a 'models' folder inside the ~/.gazebo directory and now it worked. Not sure why Gazebo was not able to create that folder itself. Wrong permissions maybe? I'm still interested in the reason, so if anyone has a clue let me know. Thanks!
Asked by JROS on 2018-11-07 17:19:53 UTC
