Problem with starting gazebo
I installed Gazebo last week and Gazebo crushed when building a simplified vehicle 3D model. I failed to relaunch it because of the following error:
  terminate called after throwing an instance of 'std::bad_alloc'
   what():  std::bad_alloc
I deleted Gazebo and reinstalled Gazebo later, but still facing the same problem. I tried methods from this link: http://answers.gazebosim.org/question/18805/problem-with-gazebo-stdbad_alloc/ , while it does not work either. So what should I do to solve the issue?
Thanks
Asked by JonOuyang on 2018-11-20 11:06:50 UTC
Could you add more context to your question, like what Gazebo version are you using, how did you install it, and the exact steps to follow to reproduce your problem? Thanks!
Asked by chapulina on 2018-11-20 12:36:33 UTC
