How to get instantaneous velocity value when using gazebo ros_diff_drive plugin
I am using the following gazebo plugin to model a diff drive mobile robot in gazebo and then doing a PID for velocity control of the mobile robot.
I understand that in order to do a PID controller for the movement, i need to sense the current velocity of the robot. and get the error between that and the reference velocity.
Problem is then how do I get the current velocity?
<gazebo>
<plugin name="next_controller" filename="libgazebo_ros_diff_drive.so">
<publishWheelTF>false</publishWheelTF>
<publishWheelJointState>true</publishWheelJointState>
<legacyMode>false</legacyMode>
<updateRate>100</updateRate>
<leftJoint>wheel_left_joint</leftJoint>
<rightJoint>wheel_right_joint</rightJoint>
<wheelSeparation>0.343</wheelSeparation>
<wheelDiameter>0.164</wheelDiameter>
<wheelAcceleration>1</wheelAcceleration>
<wheelTorque>10</wheelTorque>
Asked by someonekarl on 2018-11-30 00:31:41 UTC
